strange error
St3
Aspiring Champion
Fixes: 5
strange error
Ive just done a wipe/fresh install of windows 10 and my network adaptor has disappared from device manager, im not able to install drivers for it............. its never happened before so im not sure why its done it now.
Ive tried a few things and its still missing ahhh anyone had this problem before ?
5 REPLIES 5
Browni
Aspiring Hero
Fixes: 60
Re: strange error
If it is actually missing you probably need to update the chipset drivers, do you have a motherboard driver disk?
St3
Aspiring Champion
Fixes: 5
Re: strange error
i re downloaded windows 10 and now its working again, but the windows 10 verison i have seam alot different to the one i had before i wiped.
I downloaded it from here https://www.microsoft.com/en-gb/software-download/windows10
Browni
Aspiring Hero
Fixes: 60
Re: strange error
You're probably on the Creators Update version (1703)
Running winver will tell you.
rongtw
Fixes: 12
Re: strange error
@St3 its more than likely to have been a windows update missing from your previous win10
Browni
Aspiring Hero
Fixes: 60
Re: strange error
@jaread83 I've just been notified of Ron's reply above at 4:25am
