strange error message
- strange error message
05-02-2008 9:26 PM
I have suddenly started getting a box appearing regularly on screen marked error - and saying "warning. Cannnot find flash ocx "
Does anyone know why or what that is?
5 REPLIES 5
Re: strange error message
05-02-2008 9:32 PM
1)Could say its a man,
2) flash is a video player that you normally have you download, do you have it on your machine, it has been upgraded in the last week
05-02-2008 9:35 PM
when I got a message on screen last week about upgrade I accepted that - so is it something to do with that?
05-02-2008 9:41 PM
I will have to get my fingers coordinated.
I haven't had any problems since upgrade, I have two machines, Win98 and XP, both are OK
05-02-2008 9:54 PM
Just done a google search, it suggests it might be a registry error, there is a non macromedia scan and fix program, but I would like to use a genuine macromedia program for that
http://www.fix-macromedia-flash.com/
05-02-2008 10:26 PM
Thanks Pierre for mentioning Google. I did a search for flash ocx and found a helplne website that said because I had a third party screen-saver which used flash it was looking for the flash.ocx whereas due to update it was now flash9.ocx.
so very carefully I followed the instructions it gave and so hope now I do not get error message back!
