spreadsheet question
journeys
I've a number (say 5.61678e-21) we will call A, another number B (say 0.0014)
If A = Bn what function do I use to find n
Having a senior moment...................
5 REPLIES 5
HPsauce
Re: spreadsheet question
2 questions back at you:
1. Is n integer or something else?
2. What spreadsheet are you using?
It will probably be some sort of exponent function.
PeterLoftus
Fixes: 5
I think it will be a log function  Smiley
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
pwatson
Mathematically
n=LogBA
In Excel the function LOG takes parameters Number and Base so =LOG(Cell 'A', Cell 'B') should work
PeeGee
try:
=log10(A)/log10(B)
or
=ln(A)/ln(B)
(the answer is the same  ~ 7.0958 for the given A and B !!!!)
Phil
(lapsed CMath)
Plusnet FTTC (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
journeys
doh, ...................comes back to me now, Thanks guys - drinks on me - works a treat, (am using excel, n is not an integer).
