spreadsheet question
- Re: spreadsheet question
07-09-2014 8:25 PM
I've a number (say 5.61678e-21) we will call A, another number B (say 0.0014)
If A = Bn what function do I use to find n
Having a senior moment...................
5 REPLIES 5
07-09-2014 9:03 PM
2 questions back at you:
1. Is n integer or something else?
2. What spreadsheet are you using?
It will probably be some sort of exponent function.
07-09-2014 9:05 PM
I think it will be a log function
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
07-09-2014 9:17 PM
Mathematically
n=LogBA
In Excel the function LOG takes parameters Number and Base so =LOG(Cell 'A', Cell 'B') should work
n=LogBA
07-09-2014 9:20 PM
try:
=log10(A)/log10(B)
or
=ln(A)/ln(B)
(the answer is the same ~ 7.0958 for the given A and B !!!!)
Phil
(lapsed CMath)
=log10(A)/log10(B)
or
=ln(A)/ln(B)
Phil
(lapsed CMath)
Plusnet FTTC (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
07-09-2014 9:25 PM
doh, ...................comes back to me now, Thanks guys - drinks on me - works a treat, (am using excel, n is not an integer).
