spell check for plus email
timberwoody
I have migrated to plus from orange. In orange email a spell check was included. I do not have one in my plus email set up. Please can anyone tell me how I can check my spellings in plus email? I am using mozilla firefox for my browser.
Regards
timberwoody
Plusnet Staff
Plusnet Staff
Fixes: 159
Re: spell check for plus email
Hi timberwoody,
I'd suggest something similar to https://addons.mozilla.org/en-US/firefox/addon/3366 , it'll spell check for you as you type in firefox and comes in quite handy.
 Chris Parr
 Plusnet Staff
pierre_pierre
if you are using Outlook Express, you should have Spell Check installed, on top bar when composing new mail.
timberwoody
Many thanks Chris I will give that a try!
Regards
timberwoody
timberwoody
Hi Chris I have installed the add on from your link! I now get a red underline on all spelling mistakes but they do not get corrected automatically!
Please help.
regards
timberwoody
James
If you right click on the word with a line, it should give you an option of a correctly spelt word.
timberwoody
many thanks Jameseh and Chris my problem is now solved!
kind regards
timberwoody.
James
Glad it helped Smiley
