speedtest-cli
PeeGee
speedtest-cli
Anyone tried speedtest-cli (uses speedtest.net servers)? I often get a negative spike with Samknows around 21:00 (+/- 1hr) - see image, where the drop is 70% to 22Mbps Cry
The drop is variable, from 3% to 50% usually, though the BTW test hasn't shown a significant drop on the odd occasion I remember to run it at a suitable time, so I want to see if it is the route SK uses that's the problem (unless SK uses the same servers, of course Shocked Roll eyes ).
I've tested speedtest-cli with Mint17 and it seems to be giving results close to the BT values, so I've set cron to run it 5 minutes before/after 8, 9, and 10PM and log the results.
Phil
Plusnet Fibre (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
Fixes: 21
Re: speedtest-cli
You got anything that switches on/off at 9?
Not tried the cli version will have a look at it.
PeeGee
Re: speedtest-cli
HB,
Have a look at this page.
The only fixed timing internally is heating/hot water; nowhere near the 20-22:00 slot, everything else is "random". The graph below covers January and the only spike not in the slot is 16:00 18th January (third from right), plus there are 7 "slots" where the variation is below 2Mbps; with 2 each on Wed, Thurs and Sat.
There's no "heavy" industry nearby, but the local A&E hospital is 100m away (direct line), with a common 4.1km (of my 4.5km) to the exchange, assuming BT, and then onward. There is a possibility of power problems, of course, but the timing seems a bit strange and the transformer for the houses is just across the road. The hospital was built 8 years after the houses.
To (possibly) get a better picture as SK data is too coarse, I'm going to change the cron timings for tonight and tomorrow to run at 10min intervals from 19:05 to 22:55.
Phil
Fixes: 21
Re: speedtest-cli
Interesting, are you piping out the test to a log file?
VileReynard
All Star
Fixes: 11
Re: speedtest-cli
Not unusual (for me) - but important to see the vertical scale.
BTW speedtest-cli currently shows
jeremy@hector:~$ speedtest-cli
Retrieving speedtest.net configuration...
Retrieving speedtest.net server list...
Testing from PlusNet Technologies Ltd (87.114.xxx.xxx)...
Selecting best server based on latency...
Hosted by Peer Point Internet LTD (London) [2.52 km]: 21.328 ms
Testing download speed........................................
Download: 47.04 Mbits/s
Testing upload speed..................................................
Upload: 16.44 Mbits/s
PeeGee
Re: speedtest-cli
Yes, mmm - must do better (see below)! Looking at your graph, perhaps mine isn't so bad Roll eyes
@HMcB
Yes, append date/time to the file and pipe via "grep Mbits >>"
Again, must do better - made my usual mistake of testing directly and forgetting the full path for the commands under cron, even though I tell myself to not forget next time Crazy so no data this PM Shocked Cry
Phil
PeeGee
Re: speedtest-cli
Not much variation for the last two nights, but the detail for yesterday (21st) is below. Samknows in blue, speedtest-cli in red. Spacing is a bit wayward due to plotting two series Roll eyes
Fixes: 21
Re: speedtest-cli
Anything downloading at that time?
A movie streaming or an update?
PeeGee
Re: speedtest-cli
Not that I know Roll eyes I was playing a couple of "freesat" recordings at that time, not streaming.
I had done some updates in the afternoon and there's automated mail fetch on the hour/half-hour (but no e-mails!) All other automated tasks don't fit in the time period.
There's a possibility the freesat unit was doing something in the background (it does seem to fetch things at times), perhaps I should try disconnecting it when it's not needed (though that seems to stop the "teletext" service).
The system I'm currently using was off, so no other internet activity.
