speedtest.btwholesale gives eratic readings on linux using firefox
Mazda
I had seeming lags with browser & reported fault after testing with BT Speedtest showed very low speeds.
  I use linux mint ,firefox , all latest versions & the test readings are all over the place.
If I use the Google Chrome browser, still on linux mint - it gives consistent stable & high readings.
Same result using separate laptop, using linux also, & using different router.
Line has been tested OK by BT who visited premise. I usually get noisy line every 2-3 years, so thought same problem reappeared.
saw same problem reported on these forums by different user.
This is something Plusnet needs to look into, as it's part of their user diagnosis tutorial.
2 REPLIES 2
VileReynard
Fixes: 20
Re: speedtest.btwholesale gives eratic readings on linux using firefox
Try http://www.speedtest.net/ if you want consistency.
You could try downloading a Linux distro if you want to see what the true download speed is.
Bit torrent works best at saturating your connection.
Mazda
thanks ,  yes I will stick with http://www.speedtest.net/  now.
