smart tvs
- Re: smart tvs
smart tvs
22-10-2014 8:14 PM
does anyone have any problems getting thier laptop to smart tv hooked up as im having trouble sorting mine out as my new ty does not wont to pick it up and plusnet dont seem to know how to help as they say they have not heard of "intrution detection" or somthing can any one help me.
5 REPLIES 5
Re: smart tvs
22-10-2014 8:39 PM
Well if you can give is a bit more information on your TV, how your connecting it and the source of the error, that would be helpful.
Re: smart tvs
22-10-2014 8:48 PM
My TV is a bit thick - but I can still connect via DLNA+LAN or via PC -> Raspberry Pi+LAN -> TV.
Haven't tried a direct VGA connection.
Re: smart tvs
22-10-2014 9:58 PM
do you mean "intrusion detection" ?
and where is that "intrusion" being registered, is it on the laptop, router or tv ?
if its on the laptop and it directly relates to the TV connection chances are you need to change the firewall settings for that connection.
if its on the TV then again chances are you need to change a setting
if its on the router chances are there is a problem with the TV calling home and an the update server appearing to send an unsolicited connection attempt to the TV's default LAN address (which is in all likelihood the wrong one for your LAN)
make and model of both tv + laptop any firewall software details and router make/model would also greatly help with any attempts to give advice
Re: smart tvs
22-10-2014 10:40 PM
i have a samsung smart TV and i connect my PC and lappy VIA samsung share
Re: smart tvs
22-10-2014 11:11 PM
How do you get your TV programme list if it doesn't do a download via the internet?
(Unless you only want freeview programmes).
