skype on windows 8
- skype on windows 8
skype on windows 8
17-03-2014 9:22 AM
How do I delete a contact on skype using windows 8?
2 REPLIES 2
Re: skype on windows 8
17-03-2014 10:10 AM
Not sure if this works as i dont use it but found this googling hope it helps
In skype, scroll over to your contacts. Click on the contact as if you were to start a conversation. Then, anywhere on the screen, right click once. At the very bottom right corner of your screen will be 3 buttons. The one in the very corner will show a skype person symbol with an X and will say "remove" beneath it. Click on this, and it will ask you "are you sure?"
http://community.skype.com/t5/Modern-Windows-from-Windows/Removing-a-contact-in-windows-8/td-p/12951...
http://community.skype.com/t5/Modern-Windows-from-Windows/Delete-a-contact/td-p/1171730
17-03-2014 9:26 PM
Yep works like a beauty thanks mate
