shifting start page icon
Fixes: 9
Does anyone know how to shift the mozilla firefox start page icon from the right hand side of the taskbar to the left hand side  FF6
A Left click on the icon gets you to a customise page but there is no icon for the start page .
In an earlier version of FF it was possible to drag it across to the other side, has this facility been removed ?
Fixes: 62
Re: shifting start page icon
Do you mean the new tab icon as this
Fixes: 9
no, I mean the little house icon.
I can shift everything else but that.
Steve
Seasoned Pro
Right click on your browser and select customize then drag the house to the window that just popped up and then from there drag and drop It to the other side.
If life gives you lemons, make lemonade.
rongtw
Fixes: 12
cheers steveM  Wink i found that a  usefull tip
Fixes: 62
Do you mean like this.
As Steve said - Except I just right click on the tool bar, select customise and drag the house to where you want.
The only proviso - I am running the Firefox 3 scheme as I hated the Firefox 4 version
rongtw
Fixes: 12
mine looks like this oldjim  Wink  FF6
Fixes: 9
Got it.
I was looking at the customise window and couldn't see the icon there but by moving the cursor to the house icon whilst the customise window is displayed the hand appears and allows you to drag it across as you all describe.
thanks for that !!
