setting up php site
harish
setting up php site
I asked plusnet to configure my webspace to allow .php files. I upload werb pages with the .php extension and each time I'm asked if I get a popup appear asking me if I want to open or save the file.
Has anyone ever experienced this?
I can view normal html files but that is it?
Any help would be greatly appreciated.
Fixes: 103
Re: setting up php site
Sounds like you're uploading content to the Homepages servers that don't support PHP. You need to be uploading the files to the cgi platform at cgi.plus.net. This is accessed via a web browser using http://cgi.username.plus.com.
netman
harish,
Have you got this sorted as I went through the same problem and am somewhat of an expert on the cgi side of things. Be warned though that PN have upgraded there PHP4 to PHP5 and there are some issues.
