setting up .co.uk e-mail outlook 2007
Brickinit
i have had a major crash on my PC which has ment me having to reinstall Win XP and Office 2007, i have set up Outlook to recieve my e-mail for  me@domain.plus.net but i can't for the life of me remember how to set up my plusnet hosted .co.uk email account, me@domain.co.uk have looked at the help pages but still can do it. lucky i had quite a recently saved .pst file, if anyone can give me some pointers with this it would be much appreciated.
Fixes: 20
Re: setting up .co.uk e-mail outlook 2007
Go to your member s page > left hand side.... My Account > Email settings > manage my mail > (find tab) Aliases > under "add a new alias"  enter new alias in box.....then click ADD on the bottom of the page...
(I think... !  )
I am sure someone will correct me if I am wrong !... Embarrassed Undecided Undecided
Brickinit
sorry what i ment was to set up my .co.uk e-mail account in Outlook.
it should still be set up in Plusnet as that hasn't been altered
Fixes: 178
Mail to your hosted domain should be delivered to your default mailbox (domain.plus.net)
Customer and Forum Moderator. Windows 10 Firefox 64.0 (64-bit)
Denzil
Any email client can be set up to retrieve email from a number of domains, wherever they are hosted. If email to your domain is not directed to your default mailbox you just need to set up a new account and enter the login details. There is a guide here for Outlook.
Once you have set up a second account it will be visible as a separate set of folders in the left hand pane.
pierre_pierre
I have three domain names, user.free-online.co.uk,  user.idps.co.uk  and user.me.uk  all supplied by PN,  they are all delivered to my free-online address by default, no need for an entry in OE.  But you can sort and reject on the full name if you want.  But if you want to send by a particular extension, you have to set up a mailbox
Brickinit
i think my problem is i can not remember my password for that domain, have raised a ticket 24 hours ago but no reply as yet.maybe tommorrow!!!!
Fixes: 167
Re:setting up .co.uk e-mail outlook 2007
Any emails sent to your @domainname.co.uk address will be received by the same @username.plus.com mailbox.
You don't need a specific password for your domain, you collect mail in the same way as you do for your @username.plus.com addresses.
Example:
I have a username of chris and a domain name of parr.co.uk
Any email sent to mail@chris.plus.com will also be received to mail@parr.co.uk
All you need to do in your mail client is set up the 'from' address to show as your domain email address.
 Chris Parr
 Plusnet Staff
pierre_pierre
as far as sending is concerned, for the post box that you have forgotten your pass word, copy all the received mail to another box, then go into manage mail, delete that box and set up another one with the same name and a new pass word, think that should  work, you can then copy the moved mail back
