server not found (Solved)
gleneagles
Aspiring Legend
Fixes: 17
I have been trying to get on the extra energy website at www.extraenergy.com for several hours but simply get the message ' server not found'
If a website is down from a company would you not just get some logo or message to say it was down rather than a, server not found message' ?
We are born into history and history is born into us.
18 REPLIES 18
Mav
Fixes: 515
Re: server not found
I have just been able to access their site and get a quote.
Forum Moderator and Customer
Mustrum
Fixes: 77
It works OK for me.
Could it be a gateway or IP issue?
ITWorks
Fixes: 9
Works fine for me.
You may already know , extra energy , one one of the most complained about companies, record complaints.
http://www.bbc.co.uk/news/business-36704301
http://business-reporter.co.uk/2016/07/05/extra-energy-investigation-soaring-customer-complaints/
HairyMcbiker
All Star
Fixes: 21
Working for me as well.
Check with
http://isup.me
HairyMcbiker
All Star
Fixes: 21
PN should take note of:
"aims to reduce call waiting time to an average of 45 seconds" Not 45MIN
gleneagles
Aspiring Legend
Fixes: 17
Thanks for the responses,
I could get into every other web site on my desktop and tablet but not this particular one,
Will try again and be back for more advice if I am unable to access it.
Must admit I am a customer of their's so need access to see my bills, no problems with them so far, just hope it keeps that way.
gleneagles
Aspiring Legend
Fixes: 17
Still not able to access it, seems odd as every other website is ok.
Starting from fresh rather than a link I still cannot access it.
Anyone any ideas ?
A tablet using android or desktop using linux along with  several search engines, google, firefox etc but still cannot access it.
Mustrum
Fixes: 77
Which gateway are you on, and what's your IP address? Have you tried changing either?
HairyMcbiker
All Star
Fixes: 21
try using the ip rather than the url
http://91.194.180.99
Might be a dns problem.
gleneagles
Aspiring Legend
Fixes: 17
Not sure what you mean by 'gateway'......as I am not well up on these things.
Tried 91.194.180.99 but just get the message....' This site can't be reached, the server address could not be found.
I cannot understand why this is the only site I cannot access, I have had no problems in accessing this previously.
Would turning off both modem and router for a few minutes resolve it or has that nothing to do with it ?
gleneagles
Aspiring Legend
Fixes: 17
After fiddling around for a bit I went into settings and cleared the cache in google, chrome & firefox, that seems to have done the trick.
Thanks for the suggestions.
Mustrum
Fixes: 77
There have been several posts on here about people having similar issues, a lot with issues using some new IP addresses acquired from other BT Group companies based elsewhere. You can check the gateway here and your IP just by typing whats my IP in Google.
Yes, rebooting your router may change both the Gateway and the IP, but make a note of both before you do, and check again after, at least then you will know if its made a difference. If you are on the new network, it may require leaving the router off for a while, until someone else picks up your old one, but even then it may not work as well.
Mustrum
Fixes: 77
Ah, glad you got it sorted.
Browni
Aspiring Hero
Fixes: 60
Interesting that you've got it sorted as I have just tried using default DNS settings and I couldn't access the site, changed my network adapter to use Google DNS and it worked...
Go figure.
