sd card on samsung phone
morgan2476
Hi I currently have an 8gb sd card on my phone.  If I obtain a 16gb card and transfer the data from the 8gb, will this have any implications for the playlists on the phone?  Or will I have to do the playlists again?
scootie
Re: sd card on samsung phone
unsure on this.
does your samsung support 16gb of external memory?
morgan2476
Hi Asbo Dog
The spec is for 8gb, but I have looked on various websites and it seems the phone (tocco lite) will accept 16gb.  The reason I am asking this is because to make a playlist on this phone is complicated and time consuming.
Regards
matt_2k34
it should be easier to do using their samsung software IIRC.
i wouldnt recommend putting more than the recommended amount in the phone, you may find that it just wastes the battery - and gets the handset hot.
morgan2476
What is samsung software IIRC?  The software that came on the disk (pc studio) is useless - just as difficult to operate.  However, I think I will leave the 16gb didk for the time being.
Regards
