safari browser
- Re: safari browser
safari browser
13-01-2012 7:20 AM
I dwnloaded safari and it starts up in new window but then thats it!! It just hangs forever with that damn cirle thing rotating endlessly. Chrome loads and runs in seconds so whats wrong with apple safari?
8 REPLIES 8
Re: safari browser
13-01-2012 7:48 AM
What operating system are you using?
Re: safari browser
13-01-2012 12:29 PM
On my iMac, OSX 10.6.8, I use Safari 5.1.2 no problem.
Have you tried re-downloading it, or delete it and use Software Update in the menu, top left.
Which browser were you using before Safari & Chrome ?
Where are you downloading it from, it comes free with OSX, is it a purchased copy of OSX ?
Re: safari browser
13-01-2012 12:37 PM
i suspect it's on windows which is why I asked for which O/S
Re: safari browser
13-01-2012 12:38 PM
The question was asked in the Mac/Linux software section though, but yes I suspected the same.
If that is the case, I wonder if the correct version for the O/S was downloaded ?
I note he does state the rotating circle of death, AFAIK that is a Mac OSX thing.
Re: safari browser
14-01-2012 6:21 AM
Quote from: dvorak What operating system are you using?
Windows 7 on an acer i3 350m
Re: safari browser
14-01-2012 6:22 AM
From apple web site for the ninth time after deleting each time before installing
Quote from: PlusComUK On my iMac, OSX 10.6.8, I use Safari 5.1.2 no problem.
Re: safari browser
14-01-2012 6:26 AM
Just a bit more info The browser was ie9. Add to this my friend has dwnloaded this onto similar pc and it works fine so after numerous attempts to dwnload all the options ie repair files etc I think I'll stay with chrome for the time being.
Re: safari browser
14-01-2012 3:01 PM
guts of safari & chrome are mush the same (webkit) .... just stick to one you are used to perhaps?
