router recommendations
chenks76
All Star
Fixes: 12
i'm looking for a new router - for use on ADSL but can also be used with FTTC.
requirements
AC wifi
gigabit ports
i had a look at the asus dsl-ac68u and fritzbox 3490.
what do you guys use/recommend?
7 REPLIES 7
nanotm
Re: router recommendations
I have the billion 7800dx, some people use the all in one version 8800nl
but neither of them are ac wifi, although the 7800dx supports up to 600mbps 5gz wifi and gigabit lan/wan speeds
don't know the exact details of the 8800nl
why do you want ac wifi? according to Wikipedia its limited to 4 clients per AP, not to mention its so new that the majority of devices listed as "ac" wont actually be true AC for another 6 months at the retail end just as the rash of supposed "n" devices weren't really up to the finalised standard either ....
chenks76
All Star
Fixes: 12
future proofing
VileReynard
Fixes: 20
Cheap option:-
Get a Gigabit switch and use one port into your router.
The rest will operate at 80Mb on the internet, or 1Gb locally.
chenks76
All Star
Fixes: 12
how does achieve what i want?
did you even read my requirements?
PeeGee
The only thing missing is ac wifi and that, for "future proofing", could be considered an option rather than a requirement under the current development status. If you mean a modem/router combination unit (as implied by you choice of devices referenced), then it does fail to meet your (unspecified) requirement.
Plusnet FTTC (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
chenks76
All Star
Fixes: 12
i think the first line of the opening post was pretty clear what i was looking for
"i'm looking for a new router - for use on ADSL but can also be used withFTTC."
so to clarify for those that seem to be a bit hazy on this.
i am looking for a NEW ROUTER
i want it to have AC wifi and gigabit ports.
thunderer
Go to Amazon & have a look at this one, Billion BiPAC 8800AXL. But if that's right don't buy it from them because you can usually find it cheaper by trying:
http://www.broadbandbuyer.co.uk/
http://www.ballicom.co.uk/
