router issues
jenhen70
router issues
Over the last 3 days my router has gone through a routine of losing the wifi connection.  First the light flashes green, then steady green, then flashing orange, then steady orange with the broadband light on then back to blue.  It is painful as I am working from home and require a constant connection for online meetings.  Please could you advise why it is going through this pattern at least every couple of hours.  I have switched from another provider and over the last 3 years have never had a broadband issue, so I know my line is pretty solid, especially as my phone is all good too.  Thank you.
4 REPLIES 4
shutter
Fixes: 65
Re: router issues
More information about what router it is... make ... model... and who supplied it... did you buy it, or is it PlusNet issued one ?
jenhen70
Re: router issues
Hi it's the Plusnet one hub. Only signed up to Plusnet 3 weeks ago.
VileReynard
Fixes: 20
Re: router issues
Have you tried another router - an "unlocked" router can be configured for Plusnet.
bill888
Champion
Fixes: 38
Re: router issues
Description of hub lights can be found here
https://www.plus.net/help/broadband/router-setup-guides/
For the hub power light to turn green suggests the hub is actually booting up, like as if power to the hub had been turned off and on.  Could be faulty hub or power adapter?
The orange light is an indication there is no working internet connection.
I can only suggest you log into the hub by pointing a web browser to 192.168.1.254 and verify your Plusnet account username is visible, instead of the default setup@plusds.net account.
This thread should really be moved to the 'Router' sub forum imho.
ex-Plusnet (ADSL, FTTC) 2008-2023. now BT (FTTP) 2023-
