registry fix software
- registry fix software
30-11-2007 1:43 PM
can anyone recommend decent software for registry fixing
thanks in advance
Re: registry fix software
30-11-2007 1:57 PM
If you want to clear out unused registry items, try CrapCleaner its free.... does two jobs really, can be use to erase (you have to set the number of passes) the usual cookies and mrud`s etc. and can also check the registry for obsolete unused items.
Best thing its free !
30-11-2007 3:12 PM
hence really why i wanted to get others experience and recommendations..
I will check out ccleaner now...
30-11-2007 3:16 PM
which subsequently finds very few problems
30-11-2007 3:32 PM
Quote from: Strat Be advised that some 'free trials' of such software could possibly find a great many issues in order to encourage you to buy the full version...........
exactly thats why i like to go by recommendations
30-11-2007 3:49 PM
Quote from: netreg can anyone recommend decent software for registry fixing
You want to give unknown software complete authority to bypass all/any security you may have?
It's a glaring Windows security hole - anything that can write to your registry can destroy your machine.
30-11-2007 4:27 PM
Never had any problems with it and it also keeps a backup of any registry changes just in case.
Best of all its free and spyware free.
Edit: oh yeah, don't forget to deselect the yahoo toolbar when installing (unless you want it!).
Jeff
30-11-2007 4:48 PM
30-11-2007 4:59 PM
Quote from: axisofevil
Jeremy, i fully appreciate what your saying.. It not a case of giving unknown software authority.. it is simply that i want to do some housekeeping on my winxp box rather than having to rebuild it every 6 months or so because it takes longer and longer to start up.. Although now i tend to use linux which thankfully doesn't need all this but unfortunately i cannot fully move to linux due to some software i still need to use.
I have given ccleaner a go and that seems to have done the job. thanks guys...
05-12-2007 2:35 AM
05-12-2007 11:02 AM
Quote from: petlew I've found RegCure very effective, had it so long, can't remember if it's free or not, I think it is.
Regcure is no longer free it will find 500 or so errors then prompt you to buy the full product
I also use ccleaner have been for a long time absolutely great never deleted anything it shouldn't but a back up is still recommended
05-12-2007 5:25 PM
Well worth trying!
06-12-2007 8:00 AM
http://www.pctools.com/registry-mechanic/
Reviews here...
http://registry-repair-software-review.toptenreviews.com/
06-12-2007 1:15 PM
Quote from: minkey I use CCleaner (www.ccleaner.com) and that cleans registry and other bits of your system. Also quite useful for removing things from your startup.
With regards to startup entries, I find RegistryProt does a good job preventing unwanted stuff being added in the first place. You just run it in the background constantly (it only uses a few Kb of RAM).
