realupgrade.exe still running
penneck
I dont know what I am doing to start it, but often (not every time) when I try to shut my pc down now, I get a warning that realupgrade.exe is still running. I can stop it at that point, but the shutdown takes a long time when compared to how long it takes if I hadn't got that warning.
So the questions are:-
1. What is kicking off realupgrade.exe? How do I find out?
2. If it is being started by something I am using, how do I stop that something starting realupgrade.exe, because obviously I want to use whatever is starting it?
Thanks for any help
Fixes: 57
Re: realupgrade.exe still running
Real Player
Do you really need it
I should just uninstall it
Fixes: 16
It must be something to do with RealPlayer's auto updater. I expect its video downloading browser add-on could trigger it whenever you open a web browser.
Try updating RealPlayer from the menu in RealPlayer.
rongtw
Fixes: 11
you can always install http://www.filehippo.com/download_autoruns/ and check all your auto running programs & stop the ones you dont need Smiley
or you can disable it VIA ,," MSCOFIG"  from windows
Fixes: 16
I don't think realupgrade.exe itself is one of Real's main autostart programs, that's tkbell.exe, plus nowadays some spectacularly useless sounding service for "managing different versions of real downloader" or some rubbish like that. I think realupgrade.exe ends up as an entry in Task Scheduler.
shalom2010
Fixes: 57
That isn't the file we are discussing
This is http://systemexplorer.net/file-database/file/realupgrade-exe/403571
penneck
What I have done since starting this thread on the forum is, as suggested, a search of the full C: drive looking for realupgrade.exe. Anywhere I found it, I deleted it. There were problems where at least one realupgrade.exe wouldn't delete because it was already working, but I seemed to get round that by rebooting and deleting that realupgrade.exe immediately. Even that didn't completely solve the original problem. I deleted the complete Real folder, and the complete RealNetworks folder, and still the original problem persisted. Now the search of the C: drive only showed four Tasks and a Prefetch which mentioned realupgrade.exe so I deleted them as well.
Since then I have done several boots, running the sort of programs I normally used, and then shutting down, and indications were that the original problem had gone. Therefore, I have reinstalled RealPlayer, and continued the testing. Now when I search the C: drive it reveals just about the same examples of realupgrade.exe as was, but only two Tasks and a Prefetch. I'm still not getting the original problem so it looks like it has been solved, but time will tell.
Thanks to all for your help.
