raspberry pi zero
- raspberry pi zero
- « Previous
- Next »
Re: raspberry pi zero
14-09-2017 3:09 PM
however, pi-hole can't seem to do that very well (if at all).
strange how ublock origin (and adblock plus) can do it 100% of the time, yet pi-hole can't.
14-09-2017 3:22 PM
14-09-2017 3:47 PM
how can ublock origin manage it 100% of the time, yet something like pi-hole can't.
also, that link to github doesn't seem to apply to pi-hole.
it's a brower script ?
14-09-2017 4:01 PM
Maybe have a day off from the sociopathy and be grateful that Pi-hole is free and open source and a lot of work goes into maintaining it.
If you're not happy with the blacklists they provide, seek others or compile and maintain your own...
14-09-2017 4:09 PM
my initial comment stands... pi-hole says it's a "whack-a-mole process", yet the two adblock extensions i mentioned have a 100% sucess rate at blocking ads.
one seems to manage it fine, one doesn't.
it's a valid question to ask.
15-09-2017 1:20 PM
This is relevant to your question.
15-09-2017 2:56 PM
might end up just de-commisioning it as it was primarily for the devices where you can't install ublock origin (or similar) and where having to see a pre-play ad on youtuve was the main gripe.
15-09-2017 7:08 PM
15-09-2017 7:42 PM
I read all about the raspberry pi via articles published in technology websites and magazines.
and i've been using raspberry pis for various things since the original pi 1.
yet another non-sensical post from the resident walloper.
15-09-2017 7:50 PM
You could imitate pi-hole by simply putting a few thousand entries in your hosts file.
Keeping it up to date would be rather tedious, though.
15-09-2017 7:52 PM - edited 16-09-2017 5:41 PM
it also appears that keeping the pi-hole up to date with new youtube ad servers would be an equally tedious job.
compare that to unlock origin that, for me, has 100% success rate for blocking youtube ads with zero input from me.
16-09-2017 12:59 AM
Those articles are themselves are a form of indirect advertising chenks. Some articles are even created deliberately as adverts.
Then there is the original RPi that you mention.. presumably you heard about that via the media too
I wasn't having a dig at you with my previous reply BTW, I was just pointing out a simple fact - that without some form of advertising, you'd never have known about your RPi.
16-09-2017 2:03 PM
Moderator's note:
Insulting post and subsequent reply removed.
Please remember the Forum Rules particularly this section as further infractions will result in action being taken.
Forum Moderator and Customer
16-09-2017 5:39 PM - edited 16-09-2017 5:41 PM
All three words used were an accurate description of the human in question.
And remember, just because you are offended doesn't make you right.
16-09-2017 7:26 PM
- « Previous
- Next »
