" and @ keys transposed on ASUS Rog with Windows 10
- Re: " and @ keys transposed on ASUS Rog with Windo...
30-03-2016 4:14 PM
Re: " and @ keys transposed on ASUS Rog with Windows 10
30-03-2016 4:19 PM
30-03-2016 4:20 PM
30-03-2016 4:28 PM
30-03-2016 4:31 PM
30-03-2016 4:43 PM
30-03-2016 4:58 PM
Control panel/language
Against the English (United Kingdom) language bar click options (Right hand side)
Add an input method
Select the US keyboard layout you want. (you might need to experiment)
30-03-2016 6:49 PM
30-03-2016 7:35 PM
@Luzern1966 - I know the icon you mean but there isn't one on the task bar, I guess its off by default or choice.
30-03-2016 7:38 PM
I have it on my PC but I have three languages configured.
Forum Moderator and Customer
30-03-2016 9:11 PM
31-03-2016 7:49 AM
Quote from: Luzern1966 My win 10 desktop shows "ENG" and hovering over it says to switch "press windows key and space"
It really shouldn't do that unless you have explicitly told it to use a second language but a lot of 'upgraded' computers end up feeling ambiguous about whether they should use US or UK English. You frequently have to download the UK English language pack explicitly and also UK speech if you want Cortana's voice recognition to work. You can then, usually, set UK English as the display language, remove US English as an option and the ENG on the taskbar goes away. However a minority of computers have their allegiance to the US so deeply rooted that US English cannot be abolished. I saw one last week that I really had to fight to make the keyboard behave as a UK one as it would respond as US even when set to UK.
The worst thing about a US keyboard is not that the @ and " keys are transposed but that there is no £ symbol above the 3, you get a # instead.
01-04-2016 7:01 PM
