"Show Desktop" icon has disappeared
- Re: "Show Desktop" icon has disappeared
12-08-2012 8:16 PM
12-08-2012 8:36 PM
12-08-2012 8:41 PM
Forum Moderator and Customer
12-08-2012 8:42 PM
12-08-2012 8:49 PM
so Problem Solved.... (RR take note ! ! )
Thanks guys, as usual !...
12-08-2012 8:52 PM
12-08-2012 8:52 PM
Much prefer W7's Peak at desktop. though.
12-08-2012 9:03 PM
This is definitely the best forum for getting help, about just any subject. and I am so pleased that I joined PlusNet !....
13-08-2012 7:42 AM
Quote from: shutter so Problem Solved.... (RR take note ! ! )
Duly noted.
13-08-2012 12:38 PM
works quite well for me - saves having to hunt any icons out 🙂
