"How to install PlusNet Protect on up to 7 machines"
TheProfessor
Would someone please provide a link to the location of this information.  I have it installed on my main machine but would like to add another.  I must be going Crazy as I cannot seem to find it.
Thanks.
pwatson
Re: "How to install PlusNet Protect on up to 7 machines"
TheProfessor
Are you saying to simply repeat the process that I followed for the first pc (a few days ago)?  Is it that straight forward?
pwatson
From http://www.plus.net/support/security/spam/plusnet_protect_user_guide.shtml#install
If you've got Plusnet Protect as an Add-On for your service you'll be able to download and install the software for each PC you want it on. Simply follow the on-screen instructions to do this.
TheProfessor
Yes, I have.  I just switched from Norton last week but assumed, incorrectly, that a different procedure may be required for pc's 2 onwards.
Thanks for the info', pwatson.
ps sorry, jim.
