"Always ask before downloading a file fro the internet"
- Re: "Always ask before downloading a file fro the ...
18-05-2009 10:39 PM
Running XP Home version. Window with above message always appeared when clicking download file. In error, I have checked or unchecked the box and lost this window. Need this window as on the next window I can set the download filepath. Without the window it automatically downloads to a temporary file that for the life of me I cannot find. Have reset security levels in IE back to default and back to custom levels but to no avail.
4 REPLIES 4
Re: "Always ask before downloading a file fro the internet"
19-05-2009 1:00 AM
You dont say which version of IE
see http://www.mydigitallife.info/2007/06/15/reset-always-ask-before-opening-this-type-of-file-check-box...
for full instructions or get winbubble fromhttp://unlockforus.blogspot.com/2007/11/winbubbles-features-gap.html which will do it for you
19-05-2009 9:55 PM
Sorry, IE6.
19-05-2009 10:00 PM
Samuria, both look interesting but surely they are for Vista?
19-05-2009 10:28 PM
Samuria, WinBubble fixed it for me!
Many thanks, you are a genius!
