pword protect
FIXEDTopic Options
- Re: pword protect
19-07-2018 11:00 AM
hi all can anyone tell me how password protect a doc using webmail on here
Fixed! Go to the fix.
3 REPLIES 3
19-07-2018 11:09 AM
Nothing to do with webmail; you need to protect document in the word processing prog you use eg MS Word if a text document.
Same with MS Excel for spreadsheet and so on.
Re: pword protect
19-07-2018 11:31 AM
cheers for that
Re: pword protect
19-07-2018 12:08 PM
Moderator's note by Dick (Strat): Topic moved to a more appropriate board.
