pword protect
richierich007
pword protect
hi all can  anyone tell me how password protect a doc using webmail on here
3 REPLIES 3
Gel
Aspiring Champion
Fixes: 29
Re: pword protect
Nothing to do with webmail; you need to protect document in the word processing prog you use eg MS Word if a text document.
Same with MS Excel for spreadsheet and so on.
richierich007
Re: pword protect
cheers for that
Strat
Fixes: 565
Re: pword protect
Moderator's note by Dick (Strat): Topic moved to a more appropriate board.
