prodcomp1.php visual issue(s)
- prodcomp1.php visual issue(s)
27-03-2014 5:45 PM
8 REPLIES 8
Re: prodcomp1.php visual issue(s)
27-03-2014 6:12 PM
Perhaps it's supposed to be there, but it just looks like some spammy bogus search thing.
27-03-2014 6:16 PM
Nothing to do with us
You would need to raise this here http://usergroup.plus.net/forum/
However - I will do it for you referring to this post via pm
Edit
A thought - I wonder if it has been moved to the new cgi server and that has screwed it up
Edit
27-03-2014 6:33 PM
Cheers OJ
Your edited thought might be on to something (lets wait & see)
27-03-2014 6:47 PM
The Product Comparison Tool page displays OK for me on both a wide-screen display, where the navigation menus display each side (the prodcomp1.php page), and a narrow screen display, where the navigation menus are omitted (the prodcomp2.php page).
This is with Firefox 28.0 (the latest) on Vista 32-bit.
The site is not being migrated, nor due to be migrated.
David
David
David
27-03-2014 6:51 PM
It still bleeds over on standard default resolution after pressing CTRL+0 to reset to default
27-03-2014 6:55 PM
This is from IE11 and from Waterfox
Checked in Firefox 27.01 and the side text isn't there but it is in 28.0
27-03-2014 7:23 PM
Thanks OJ. The dreaded browser version problems again.
David
27-03-2014 7:43 PM
Seems to me the problem is it just won't fit into a 1280 pixel wide screen with the text at a reasonable size. Everything is appropriately placed if you zoom out a couple of times, or have a 1600 pixel wide screen.
