problems with printer since upgrading to win 10
St3
Aspiring Champion
Fixes: 5
I removed my old drivers before upgrading to win 10 and when i went to re download the new ones it told me this http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=41664&infoType=Downloads
Only problem is when i try to use the scanner it says no scanner drivers installed ... no im confused
2 REPLIES 2
nanotm
Re: problems with printer since upgrading to win 10
have you got the mfc plugged into the pc's usb port or via something else like a router ?
once its plugged directly into the pc open the devices and printers page, see what it lists it as, chances are you will have to use the add device button and manually choose your device,
if that also fails to give you the scanner option then contact Epson support about the problem and get them to provide the drivers for it to work /
St3
Aspiring Champion
Fixes: 5
least of my issues now ............. upgraded to windows ten all was good had to restart to apply updates then ... boooooooooom windows critical process died lol. So now im on my laptop downloading the iso and hopefully run a repair.
i should have left it on windows 7
