problems with media player 11
- problems with media player 11
24-12-2008 5:53 PM
I am having problems with media player 11. When I try to play a DVD the picture judders. I Have tried reinstalling media player 11 along with additional codecs but the problem persists. Has anyone any ideas please ?
Using Windows XP with intel duo 660.
Windows player did work at one time but I have installed many programs before discovering this fault.
Re: problems with media player 11
24-12-2008 7:24 PM
24-12-2008 7:26 PM
24-12-2008 10:56 PM
24-12-2008 11:20 PM
http://www.gomlab.com/eng/
See if that works ok. Have you got any other problems like installing some software or scripting errors when visiting webpages?
You could download javascript from
http://www.microsoft.com/downloads/details.aspx?FamilyId=C717D943-7E4B-4622-86EB-95A22B832CAA&displa...
why I hear you ask well Media Player uses it and if its corrupt it doesnt work and does strange things both my sons had problems with it and istalling the javascript solved it and it worked ok after so its worth a go
26-12-2008 5:00 PM
Yes, I have a Nvida card so will update the drivers as suggested. I Did have a go with VLC player on another computer about 12 months ago but after installation I had a few problems with Nero but as I no longer use Nero I Guess it would be worth trying VLC again. GOM player looks interesting so will give that a whirl as well !
Just out of interest for those people who have access to Media player could I ask why you use one of these other players ? Do they offer more than media windows player ? also if I find one I wish to stick with should I uninstall windows media player if I no longer wish to use it or will this present problems ?
26-12-2008 5:20 PM
Many programs provided with Windows are limited in the facilities - so why stick with them.
08-01-2009 5:19 PM
I have had soooo many problems with Windows Media Player over the past few weeks ...mainly that I cannot get my sound card to allow me to listen to music using WMP (must be telling me something ), that I have kicked it into touch as of today...and I now use the tried and well tested Winamp which I have had in reserve for many years.BTW, it is also free.
If you want a trouble-free player with lots of plusses and of course a great Media Library facility, try it.
cheers
08-01-2009 10:49 PM
KMPlayer - http://kmplayer.en.softonic.com/
12-01-2009 2:41 PM
check out www.doom9.org for video related informations and downloads
