printers
jimjakes
printers
I can't get my printer to operate on WiFi, can anyone help me, its an Epson Stylus SX235W. Thanks.  Embarrassed
CX
Re: printers
What have you tried so far?
Did you get any error messages (if so, what did they say)?
VileReynard
Seasoned Pro
Fixes: 11
Re: printers
http://www.epson.co.uk/Store/Printers-and-All-in-Ones/Epson-Stylus-SX235W
Says  Grin
Save money: By using four individual ink cartridges you only replace the colour used, making this an all-round, affordable device. DURABrite Ultra Ink is so versatile it is able to print lab-quality photos while at the same time produce crisp, clean text documents.
Save time: The automatic Wi-Fi set-up*3 makes configuring laptops and computers to print wirelessly extremely easy. You don’t need to know your network settings or connect with a USB cable, the SX235W automatically finds the relevant connection settings in order to configure itself. Multiple users then have the freedom to print, copy and scan quickly and efficiently from anywhere in the home.
Grin Grin
sparkrace12
Re: printers
My printer is an Epson SX420w.
I had a few probs using the software provided,and my HP laptop did recognise it, but I found the easiest way was to simply type in my IP address in the printer settings and press save on my laptop.  Cheesy
The IP settings can also be typed on my printer screen.
I use my laptop downsatirs and my printer is upstairs out of the way.
sparkrace22
