print off a laptop
jonco60
print off a laptop
can u print off a laptop to your main computer printer and do u need to install the printer software
4 REPLIES 4
PeterLoftus
Fixes: 5
Re: print off a laptop
Yes  I have done that with a EPSON Stylus DX7400.
My laptop runs vista and my desktop runs XP Smiley
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
jonco60
Quote from: PeterLoftus
thanks peter my main printer is a epson c66 and im on windows xp on both computers but how do i print off my laptop do i install my printer software onto my laptop and just press print
spraxyt
Resting Legend
Fixes: 75
I do this from an XP laptop to an HP PSC 2355 all-in-one physically connected to my Vista desktop. When setting up printing using the wizard on the laptop the HP is defined as a network printer; printer drivers are needed, but I think these were copied (over my LAN) from the printer software installed on my PC.
I think printer sharing needs to be enabled.
David
Fixes: 393
This http://support.microsoft.com/kb/814005 should help you setup the printer to be shared.
