plusnet protect
wbarnett
plusnet protect
How do I add another computer to plusnet protect
1 REPLY 1
Pettitto
Fixes: 5
Re: plusnet protect
Hi wbarnett,
On the other computer, you'll need to log into your Member Centre [ http://portal.plus.net ] and download Plusnet Protect from there and it should allow you to install Plusnet Protect on that computer.
