plusnet protect powered by mcafee serial number??
kazz44
ive finally managed to download the plusnet protect software but its asking me for a serial number to progress the installation, where can i find this? thanks
i have avg free installed but as i understand it from looking on the help articles this will be removed by mcafee as soon as the installation is complete..or should i stick with AVG? which is better?
thanks in advance Smiley
1 REPLY
Dmitchell
Re: plusnet protect powered by mcafee serial number??
Hi kazz44,
When you downloaded the setup file for McAfee you are required to accept the terms & conditions. Immediately after the terms & conditions page you should then be presented with the Serial Number. (Note: This should be copied/written down at this stage)
If you didn't manage to write this down, then simply go back to the downloads page and agree to the terms and conditions again. This will give you the serial number.
Here's the link https://portal.plus.net/McAfee/downloads.html
The page you are looking for will look like this:
