plusnet assist needs someone to assist it to actually work......
shutter
Fixes: 65
Roll_eyes
Yeah, so I thought,.... OK... I`ll download that newfangled plusnet assist, to stop getting nagged about it....
had it a few days now, and a couple of days ago, I get a popup message saying there is a "CRITICAL UPDATED FOR WINDOWS ".... click here or whatever...
so , like a looney... cllicked on it,.... up comes this screen saying when you click on [ Next ]  you will see something like this....
oh no I won`t.... been waiting for a couple of days now... ... .... ... .... ... ... .... >
so tried again today, to get this "oh so critical update"... and clicked on  [ Next ]  but still nowt happens....
`appen it needs some assistance....  Roll_eyes
5 REPLIES 5
spraxyt
Resting Legend
Fixes: 75
Re: plusnet assist needs someone to assist it to actually work......
Elsewhere (link) uninstalling and reinstalling was suggested as a way round this problem. You can check you have the new version by following the instruction in Reply #15.
David
shutter
Fixes: 65
Ha Hah!... I think  I have found out what the problem is..... I`m using Firefox... and it says it is for Internet Explorer on the top of the screen !    Roll_eyes
spraxyt
Resting Legend
Fixes: 75
Have you tried using Internet Explorer to do the update? Plusnet Assist uses functionality built into Internet Explorer but applicable options should work with other browsers.
David
shutter
Fixes: 65
Nope.... don`t use IE any more.... ...
I suppose I could do the update....... just to stop the nag screen popping up  Roll_eyes
drj
The update is done through IE...
However since Plusnet Assist only works through IE - and you don't have it any more - I can't see any option but a complete uninstall.
EDIT - spelling
