plusnet app
marilynlake
plusnet app
downloaded to my new galaxy ace, it wouldn`t let me log on. keeps saying:- check user name/ password. can anyone help please.
Re: plusnet app
One suggestion is how are you putting in the username and password? It needs to be the same as the ones you use to log in to the website rather than the ones you put into the router to connect, i.e. don't put the connection realm on the end of the username (so just username, rather than eg username@plusdsl.net).
Hope that helps,
Fixes: 167
Re: plusnet app
It's also worth noting that the developer who made the app has no affiliation with Plusnet.
 Chris Parr
 Plusnet Staff
randpwar
Re: plusnet app
Wouldn't that be a good reason for PN to create one themselves?
