phpmyadmin login error 1045
FIXED- Subscribe to RSS Feed
- Re: phpmyadmin login error 1045
09-07-2020 12:41 PM
Just when I thought, 'great, I have sorted out everything for the test starting Wednesday after months of hard work' I find that I cannot login to myphpadmin all off a sudden.
I tried to login making sure I have keyed in the correct ID and PW many times. I even restarted my computer and tried again.
Then I changed my password and tried nothing.
I have attached here the screenshot of the error message.
I have also asked the plusnet to raise a ticked but they said it will take at least three working days, which is too late.
Can someone please help?
Fixed! Go to the fix.
09-07-2020 1:53 PM
This topic has been moved from ADSL Broadband to Tech Help.
19-07-2020 10:03 PM
I have started getting this same message today. Last time I logged on was 2-3 days ago, and it was fine. Changing password etc does not help.
20-07-2020 7:59 AM
Is there anybody out there who can help with this problem?
20-07-2020 7:25 PM
I tried to raise a support ticket, but can't see this option any more. Perhaps I'll have to call them tomorrow
23-07-2020 8:17 AM
I'm considering uninstalling phpmyadmin from the control panel, then reinstalling it. However I'm not sure what files will be removed and am concerned that I might lost something that I need.
01-08-2020 8:21 AM
Issue raise by telephone a week ago. They'll get back to me.
Come on PlusNet.
08-08-2020 2:11 PM
After waiting 2 weeks for PlusNet tech support to contact me, I fiddled about some more. And found a fix.
* Go into MySQLManager, which is the database manager
* Click your user id at the top, and put in your database password. Don't hit Login, instead change the password and hit Apply. This changes the password
* PHPMyAdmin now logs on OK!
* You can change the database password back afterwards
