phone line not active
lewis123
Hi i just tried to use my phone and dont have any dialing tone ? contacted bt who installes the line who basically said its not there problem ? am i the only one or are other people out there experiencing the same problem  Angry
1 REPLY 1
RPMozley
Fixes: 13
Re: phone line not active
For phone line faults you need to contact whoever you pay line rental to. Is that BT for your line?
That's RPM to you!!
