pdnsd Vs unbound on pi
- Re: pdnsd Vs unbound on pi
21-10-2014 8:15 PM
I'm impressed with the figures on first test npr, Although I am running a locked down version of unbound with only opendns allowed for resolving unless the cache has to fall back, in which case it would use root servers instead. I do like the way you set this up to allow for cdn servers to not cache and use your isp's servers for cdn, I'm using the same block list on both by the way.
Popping a few tests below.
Cheers npr
http://www.npr.me.uk/pdnsd.html
Cheers npr
4 REPLIES 4
10-11-2014 10:21 PM
PDNSD only from here on....
Pic 1 Extended config Vs Extended config same identical hardware
Pic 2 and 3 Is 15 Extended Config 12 Basic config identical hardware
global {
perm_cache=8192;
cache_dir="/var/cache/pdnsd";
run_as="pdnsd";
server_ip = eth0;
status_ctl = on;
paranoid=on;
query_method = udp_only;
min_ttl=20s; // 20 seconds.
max_ttl=1w; // One week.
timeout=1; // Global timeout option (1 seconds).
par_queries = 3; // number of simultaneous queries.
tcp_server=off;
run_ipv4=on;
neg_rrs_pol=on;
server {
label=My_DNS;
ip=212.118.241.1; // IP address of my fastest public DNS servers
ip=212.118.241.33; // Yours will be different
ip=83.170.64.2; // Use DNS BenchMark to identify your fastest DNS servers
ip=195.12.4.247; // see https://www.grc.com/dns/benchmark.htm
ip=213.253.137.17; //
ip=212.159.13.50; //
uptest=none;
purge_cache=off;
caching=on;
proxy_only=on;
lean_query=on;
timeout=1;
source {
owner=localhost;
// serve_aliases=on;
file="/etc/hosts"; //The hosts file.
rr {
name=localhost;
reverse=on;
a=127.0.0.1;
owner=localhost;
soa=localhost,root.localhost,42,86400,900,86400,86400;
global {
perm_cache=8192;
run_as="pdnsd";
server_ip = eth0;
status_ctl = on;
paranoid=on;
min_ttl=1d; // One day.
tcp_server=off;
run_ipv4=on;
neg_rrs_pol=on;
server {
label=Cached;
ip=83.170.64.2; // Use DNS BenchMark to identify your fastest DN$
uptest=none;
purge_cache=off;
caching=on;
proxy_only=off;
timeout=1;
policy=included;
exclude=.bbc.co.uk // Do Not Use (exclude) the above DNS server$
, .bbcimg.co.uk
, .bbci.co.uk // Do Not Cache (exclude) these CDN do$
, .bbc.net.uk
, .akamai.net // These are the most common CDN domai$
, .akamaiedge.net // This list is not exhaustive.
, .llnwd.net
, .edgecastcdn.net
, .systemcdn.net
, .transactcdn.net
, .v1cdn.net
, .v2cdn.net
, .v3cdn.net
, .v4cdn.net
, .v5cdn.net
, .hwcdn.net
, .simplecdn.net
, .instacontent.net
, .footprint.net
, .yahooapis.com
, .googleusercontent.com
, .googlehosted.com
, .insnw.net
, .inscname.net
, .internapcdn.net
, .cloudfront.net
, .netdna-cdn.com
, .netdna-ssl.com
, .netdna.com
, .cotcdn.net
, .cachefly.net
, .bo.lt
, .cloudflare.com
, .afxcdn.net
, .lxdns.com
, .att-dsa.net
, .vo.msecnd.net
, .voxcdn.net
, .bluehatnetwork.com
, .swiftcdn1.com
, .cdngc.net
, .gccdn.net
, .panthercdn.com
, .fastly.net
, .nocookie.net
, .gslb.taobao.com
, .gslb.tbcache.com
, .mirror-image.net
, .yottaa.net
, .cubecdn.net
, .r.cdn77.net
, .incapdns.net
, .bitgravity.com
, .r.worldcdn.net
, .r.worldssl.net
, .tbcdn.cn
, .taobaocdn.com
, .ngenix.net
, .pagerain.net
, .ccgslb.com
, .cdn.sfr.net
, .azioncdn.net
, .azioncdn.com
, .azion.net
, .cdncloud.net.au
, .rncdn1.com
, .cdnsun.net
, .mncdn.com
, .mncdn.net
, .mncdn.org
, .cdn.jsdelivr.net
, .nyiftw.net
, .nyiftw.com
, .resrc.it
; // End of CDN list
server {
label = Uncached_CDN_Networks;
ip=212.159.13.49; // IP addresses of my ISP's DNS servers
ip=212.159.13.50; // Use your own ISP's DNS servers here
uptest = none;
timeout = 1;
purge_cache = on;
caching=off; // Cache disabled in this section.
proxy_only=off;
lean_query=off;
policy=excluded;
include=.bbc.co.uk // Use (include) the above DNS servers $
, .bbcimg.co.uk
, .bbci.co.uk // Disable Cache (include) for the$
, .bbc.net.uk
, .akamai.net // These are the most common CDN d$
, .llnwd.net
, .edgecastcdn.net
, .systemcdn.net
, .transactcdn.net
, .v1cdn.net
, .v2cdn.net
, .v3cdn.net
, .v4cdn.net
, .v5cdn.net
, .hwcdn.net
, .simplecdn.net
, .instacontent.net
, .footprint.net
, .yahooapis.com
, .googlehosted.com
, .insnw.net
, .inscname.net
, .internapcdn.net
, .cloudfront.net
, .netdna-cdn.com
, .netdna-ssl.com
, .netdna.com
, .cotcdn.net
, .cachefly.net
, .bo.lt
, .cloudflare.com
, .afxcdn.net
, .lxdns.com
, .att-dsa.net
, .vo.msecnd.net
, .voxcdn.net
, .swiftcdn1.com
, .cdngc.net
, .gccdn.net
, .panthercdn.com
, .fastly.net
, .nocookie.net
, .gslb.taobao.com
, .gslb.tbcache.com
, .mirror-image.net
, .yottaa.net
, .cubecdn.net
, .r.cdn77.net
, .incapdns.net
, .bitgravity.com
, .r.worldcdn.net
, .r.worldssl.net
, .tbcdn.cn
, .taobaocdn.com
, .ngenix.net
, .pagerain.net
, .ccgslb.com
, .cdn.sfr.net
, .azioncdn.net
, .azioncdn.com
, .azion.net
, .cdncloud.net.au
, .rncdn1.com
, .cdnsun.net
, .mncdn.com
, .mncdn.net
, .mncdn.org
, .cdn.jsdelivr.net
, .nyiftw.net
, .nyiftw.com
, .resrc.it.
source {
owner=localhost;
rr {
name=localhost;
reverse=on;
a=127.0.0.1;
owner=localhost;
11-11-2014 2:04 PM
A test from windows machine, meh.....
13-11-2014 6:58 PM
13-11-2014 7:16 PM
Edit of above Extended config, Deleted: lean_query=off; And Changed: min_ttl=1d; // One day. to: min_ttl=20s; // 20 seconds.
global {
perm_cache=8192;
run_as="pdnsd";
server_ip = eth0;
status_ctl = on;
paranoid=on;
tcp_server=off;
run_ipv4=on;
neg_rrs_pol=on;
server {
label=My_DNS;
uptest=none;
purge_cache=off;
caching=on;
proxy_only=on;
lean_query=on;
timeout=1;
source {
owner=localhost;
rr {
name=localhost;
reverse=on;
a=127.0.0.1;
owner=localhost;
global {
perm_cache=8192;
run_as="pdnsd";
server_ip = eth0;
status_ctl = on;
paranoid=on;
tcp_server=off;
run_ipv4=on;
neg_rrs_pol=on;
server {
label=Cached;
uptest=none;
purge_cache=off;
caching=on;
proxy_only=off;
timeout=1;
policy=included;
, .bbcimg.co.uk
, .bbc.net.uk
, .llnwd.net
, .edgecastcdn.net
, .systemcdn.net
, .transactcdn.net
, .v1cdn.net
, .v2cdn.net
, .v3cdn.net
, .v4cdn.net
, .v5cdn.net
, .hwcdn.net
, .simplecdn.net
, .instacontent.net
, .footprint.net
, .yahooapis.com
, .googlehosted.com
, .insnw.net
, .inscname.net
, .internapcdn.net
, .cloudfront.net
, .netdna-cdn.com
, .netdna-ssl.com
, .netdna.com
, .cotcdn.net
, .cachefly.net
, .bo.lt
, .cloudflare.com
, .afxcdn.net
, .lxdns.com
, .att-dsa.net
, .vo.msecnd.net
, .voxcdn.net
, .swiftcdn1.com
, .cdngc.net
, .gccdn.net
, .panthercdn.com
, .fastly.net
, .nocookie.net
, .gslb.taobao.com
, .gslb.tbcache.com
, .mirror-image.net
, .yottaa.net
, .cubecdn.net
, .r.cdn77.net
, .incapdns.net
, .bitgravity.com
, .r.worldcdn.net
, .r.worldssl.net
, .tbcdn.cn
, .taobaocdn.com
, .ngenix.net
, .pagerain.net
, .ccgslb.com
, .cdn.sfr.net
, .azioncdn.net
, .azioncdn.com
, .azion.net
, .cdncloud.net.au
, .rncdn1.com
, .cdnsun.net
, .mncdn.com
, .mncdn.net
, .mncdn.org
, .cdn.jsdelivr.net
, .nyiftw.net
, .nyiftw.com
, .resrc.it
server {
uptest = none;
timeout = 1;
purge_cache = on;
proxy_only=off;
policy=excluded;
, .bbcimg.co.uk
, .bbc.net.uk
, .llnwd.net
, .edgecastcdn.net
, .systemcdn.net
, .transactcdn.net
, .v1cdn.net
, .v2cdn.net
, .v3cdn.net
, .v4cdn.net
, .v5cdn.net
, .hwcdn.net
, .simplecdn.net
, .instacontent.net
, .footprint.net
, .yahooapis.com
, .googlehosted.com
, .insnw.net
, .inscname.net
, .internapcdn.net
, .cloudfront.net
, .netdna-cdn.com
, .netdna-ssl.com
, .netdna.com
, .cotcdn.net
, .cachefly.net
, .bo.lt
, .cloudflare.com
, .afxcdn.net
, .lxdns.com
, .att-dsa.net
, .vo.msecnd.net
, .voxcdn.net
, .swiftcdn1.com
, .cdngc.net
, .gccdn.net
, .panthercdn.com
, .fastly.net
, .nocookie.net
, .gslb.taobao.com
, .gslb.tbcache.com
, .mirror-image.net
, .yottaa.net
, .cubecdn.net
, .r.cdn77.net
, .incapdns.net
, .bitgravity.com
, .r.worldcdn.net
, .r.worldssl.net
, .tbcdn.cn
, .taobaocdn.com
, .ngenix.net
, .pagerain.net
, .ccgslb.com
, .cdn.sfr.net
, .azioncdn.net
, .azioncdn.com
, .azion.net
, .cdncloud.net.au
, .rncdn1.com
, .cdnsun.net
, .mncdn.com
, .mncdn.net
, .mncdn.org
, .cdn.jsdelivr.net
, .nyiftw.net
, .nyiftw.com
, .resrc.it.
source {
owner=localhost;
rr {
name=localhost;
reverse=on;
a=127.0.0.1;
owner=localhost;
