pc wont boot up please help
chelle
Hi got up this morning and my pc wont boot up
It starts up normal then asks if i want to boot up in different modes
tried all modes then it just repeats the cycle
Any ideas anyone  Huh
Fixes: 62
Re: pc wont boot up please help
If you are using XP and have an install disk can you boot from that disk
chelle
No it wont boot from disc either
Huh
Fixes: 62
Exactly how far does it get when you get the option for different modes - is this the windows option safe mode etc. or a bios option.
As you have an operating computer can you create a BartPE boot disk  http://www.nu2.nu/pebuilder/ and see if that works on the other machine.
I assume that the bios boot order is CD first then hard drive
chelle
Yes it gets to safe mode and its set up to boot from cd -it said hit any key to boot from disc which i did. then started asking again which mode to boot up in i will have alook at the other option you gave dont know that much about comps though Roll eyes
Thanks very much for your help
chelle
Havnt got aclue about the other lol
Fixes: 62
With that program by following the instructions at the bottom of the link you can burn a bootable CD
However I suspect that something rather odd is happening as you can't boot from the windows CD
While we wait for someone with a better idea can you try something rather silly.
Disconnect the computer from the mains for a few minutes then reconnect it and try again.
Many PCs don't come with a Windows install CD but a manufacturers recovery CD.
What does it say on the CD you are trying to boot from?
Also what make/model PC are you using?
chelle
Hi thanks its a recovery cd  I have a fujitsu siemens scaleo p
computer
Then please be aware that some recovery CDs will restore the system back to the factory default windows installation causing all your user data to be lost!
However, the CD should be bootable so there must be something seriously wrong with the PC, and given your technical knowledge, you may actually do more harm and potentially lose all your data if you continue.
Do you have a friend or other family member who may know more about PCs who could look at it. Failing that you may have to take it to a local PC repair shop, although they are unlikely to guarantee to retain any of your data.
chelle
ok thanks was worried it was somthing serious i will take it to the shop shortly
Thanks everyone for all your help
Will
One way to find out is, boot to safe mode with command prompt.
It will give you a list of files it is loading, you could simply just wait until it reboots and give us the name of he file it is rebooting on.
I bet it's probably agpCPQ.sys......bloody nightmare that file.... Sad
chelle
computer is in shop guy thinks ive downloaded a virus
i get it back at  4  fingers  crossed
Slick
try and learn alittle about pc's and reload windows every 2 months,
i back up my data and registry then reload windows
and restore it back to how it was but with a clean windows on it Wink
Will
You shouldn't need to do that.
I run my WinXP for like 2 years between formats, and even then, I only reinstall because drivespace seems to disappear into an abyss.....
