password manager
timberwoody
password manager
I have just installed a new PC running windows 7. For emails I use firefox 3.6. On my old PC I used easy password manager but I have been told this does not work with windows 7.
please can anyone recommend a system to install?
TIMBERWOODY
Fixes: 62
Re: password manager
Are you referring to webmail.
If so you don't need Password Manager as Firefox will remember them on it's own
timberwoody
Thanks OLDJIM , No I need to keep all my user names and passwords together for all the various sites I visit!
TIMBERWOODY
Fixes: 62
I have the same problem but all I did was create a text file with information in it  Grin
You could try this http://www.efficientpasswordmanager.com/
Fixes: 20
With Firefox I use snixper (search for it in the addon/extensios) it renumbers usernames/passwords etc. I also use xmarks to backup my bookmarks across machines.
Denzil
Quote from: timberwoody
TIMBERWOODY
Yes, but Firefox does this anyway. Whenever you enter a new password it gives you the option to remember it. You can manage the saved passwords by clicking on Tools - Options - Security, then the Saved Passwords button.
timberwoody
Many thanks OLDJIM , I have installed your password manager and put in my details. Also thank you BIKER955  for your suggestion.
Once again PLUSNET FORUM has solved my problem!
TIMBERWOODY
timberwoody
Thanks DENZIL just seen your post and taken note!
Timberwoody
