outlook express failure
chrisrobson
When I Open Outlook express (in Microsoft Office Professional), it opens and, 1 second later, closes.  Any suggestions?Huh
Fixes: 238
Re: outlook express failure
Outlook Express isn't part of MS Office it comes free with the OS.
Office ships with Outlook.
Whenever this has happened to me with Outlook it's been either because there is insufficient disc space or a dat file has become corrupt.
There's a trouble-shooter here which may help.
Forum Moderator and Customer
Fixes: 174
...or it's a pirate copy known to Microsoft....not that I'm suggesting it is. Smiley
Customer and Forum Moderator. Windows 10 Firefox 64.0 (64-bit)
Quote from: Strat
It wouldn't behave like that if it was.  Wink
I guess we need to know first if it's Outlook or Outlook Express that has the problem.
(Outlook does has a very handy "safe mode")
Fixes: 238
Quote from: HPsauce
The link I gave does give a rather long-winded way of starting Outlook in Safe Mode. For the 2007 edition simply hold CTRL as you start it. Not sure if it's the same for previous versions.
chrisrobson
Thanks for the comments.  Its Outlook that's the problem - sorry!  I've tried opening in safe mode as suggested -- using CTRL.  Didn't affect it.
Do other components of Office work OK, e.g. Word, Excel, Powerpoint?
What version (e.g. 2003, 2007) of Office Professional is it?
Fixes: 238
Try moving the dat and pst files to a new folder, restart Outlook and let it rebuild the dat file then move the pst file back to its original folder. I'm sure that's how I solved a problem some time ago.
If you go to File - Data File Management and the select the Data File tab you can open the relevant folder. Then close Outlook.
