outlook express failure
- Re: outlook express failure
06-11-2010 11:46 AM
06-11-2010 12:43 PM
Office ships with Outlook.
Whenever this has happened to me with Outlook it's been either because there is insufficient disc space or a dat file has become corrupt.
There's a trouble-shooter here which may help.
Forum Moderator and Customer
06-11-2010 2:59 PM
06-11-2010 3:33 PM
Quote from: Strat ...or it's a pirate copy
It wouldn't behave like that if it was.
I guess we need to know first if it's Outlook or Outlook Express that has the problem.
(Outlook does has a very handy "safe mode")
06-11-2010 3:54 PM
Quote from: HPsauce (Outlook does has a very handy "safe mode")
The link I gave does give a rather long-winded way of starting Outlook in Safe Mode. For the 2007 edition simply hold CTRL as you start it. Not sure if it's the same for previous versions.
06-11-2010 4:47 PM
06-11-2010 5:17 PM
What version (e.g. 2003, 2007) of Office Professional is it?
06-11-2010 6:19 PM
If you go to File - Data File Management and the select the Data File tab you can open the relevant folder. Then close Outlook.
