outlook express email settings
- outlook express email settings
30-08-2009 9:59 PM
Can anyone direct me to a blow by blow instruction in detail to set up a tiscali.co.uk address using Plusnet.broadband.
With thanks
Re: outlook express email settings
30-08-2009 10:35 PM
Account name username@tiscali.co.uk
Incoming email (POP3) pop.tiscali.co.uk
30-08-2009 10:47 PM
Have followed instructions but what should be in Outgoing mail, still not working, before being taken over by Plusnet I was with metronet and so entered smtp.metronet.co.uk
30-08-2009 10:48 PM
This may help http://www.plus.net/support/email/setup/outlook_express.shtml
30-08-2009 11:05 PM
30-08-2009 11:18 PM
31-08-2009 9:56 AM
Can you access it using Tiscali Webmail
31-08-2009 12:34 PM
you get 6 or 7 months use of the old email account from when you terminate an ISP & switch to another -- don't you - then they block you off
Quote from: Oldjim It is possible Tiscali have blocked your account since you have left them.
31-08-2009 12:45 PM
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
31-08-2009 3:46 PM
Looking at Plusnet email advice I see they say the default email address in OE must be the login details for Plusnet? I will experiment with that!
Sorry but I may be back!!
