others see a video (live cam) feed here?
Gel
Seasoned Pro
Fixes: 16
I use 3 and a half browsers; ie I have IE7 & 8 installed, plus AVANT.
Above have problem with Link camera at
http://www.newburytoday.co.uk/webcam.aspx
then select
Newbury market place.
This takes you to:
http://195.12.20.166/
address but for me it's blank.
Just get a page not found.
Streaming doesn't work with any of these, and many others looking at that paper's forums;
I discovered though that the ORCA browser did actually run the video. and sees link as
http://195.12.20.166/home/homeJ.html
Why do other browsers seem to fail to get there as it were?? Cry
4 REPLIES 4
Fixes: 62
Re: others see a video (live cam) feed here?
Firefox 3.5.7 gets there after selecting java viewer but it is appallingly slow.
It seems to give 3 viewing options Java, ActiveX and something called Server Push
Note that it says you need IE6 to view it properly
Fixes: 10
I eventually managed to get to the Java one using Firefox - but it is very, very slow!
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Gel
Seasoned Pro
Fixes: 16
pierre_pierre
your last edited link got there in about 10% of the time that the previous did - Fireforx 3.5.7
