open office to MS Office conversion
Can anybody recommend a converter to convert opd (open office power point) to ppt (Microsoft office powerpoint). That works!
I've googled converters come up with a list that more or less do everything but convert, sometimes only the first slide gets converted.
(wasted a day on it, should have asked here first)
Fixes: 57
Re: open office to MS Office conversion
I assume you tried save as in Open Office then select ppt
@oldjim, I don't have open office, somebody has just emailed me 20+ opd files, all I wanted was quickly convert them. Undecided
Thought it would run into 100 of MBs, looks like OpenOffice is only 37MB, so will download
Fixes: 15
Why not just download open office then? Or Libre Office? Be quicker to get it &install it than faff about further.
RPMozley
37MB doesn't sound like the full program, are you sure it's not just the language pack installation? It should be more than 100MB and less than 200MB. Libre is probably better as I don't know what's happened to open office now (Apache?).
Fixes: 13
just checked the size of my copy of Open Office.org 3.3   on Absolute Uninstaller,..... it says 365.9 MB
as HB says... it will be quicker to download and install it... (certainly quicker than all day ! ! ) . it is FREEEEEE.... and then you won`t have to worry about people sending you files you have to spend all day looking for conversion stuff.!
Thanks all, downloaded libre office and working.
should have asked here first ........doh Embarrassed
