o2 XDA2i Not connecting Wifi
FoolishlyWise
I dont really know if anyone can help me (hopefully people can)
Ive got a XDA2i for free from a mate. The mobile internet will work, but not the WiFi. Im using WPA2-PSK with AES (with no option for TKIP) on a Netgear DG834G. When I put in my key, it loops in scanning/connecting. I have double, triple, quadruple that its right. It will connect to someone elses network that is WPA2.PSK. The XDA doesnt have a option for WPA2.PSK AES, only for TKIP and WEP. I tried a WEP router, where only 192.168.1.1 only displays - nothing else.
Any help is Really Really appreciated.
Aman
6 REPLIES 6
Fixes: 395
Re: o2 XDA2i Not connecting Wifi
This http://forum1.netgear.com/showthread.php?t=10683&page=4 seems to describe a similar problem with the PS3. The last page seems to indicate that f/w 4.1.37 fixes the problem. Have you tried that ?
FoolishlyWise
Hello MisterW
The problem is...Ive got the DG834Gv4 ....not v3 for which the firmware is designed for.  Cry
Fixes: 395
If you're feeling brave you might look at the DGTeam firmware http://dgteam.ilbello.com/
FoolishlyWise
Well, Having a look at things....Im the opposite of brave. Any other ideas ( I need the XDA on WiFi quick)
Regards
Aman
Fixes: 395
Have you tried setting the DG834 to WPA rather than WPA2, its still pretty sucure on that setting if you use a reasonably long ( random ) passphrase.
FoolishlyWise
Yes Ive tried that but no luck  Cry
Any Other ideas?Huh
