non standardization of units in computing
- Re: non standardization of units in computing
18-07-2017 3:17 PM
people think Mb means MB they are not the same
actually mb mB Mb & MB are all different
even mb & mb can be different size depending on what is measured. { yea no typo both are lower case}
some measurements even use the WRONG symbols . ie using GB when it should be BB { think HDD or USB pen drive etc} is the reason your pc sees your HDD 7% smaller than you think you have
there are 8 bits to a byte or 10 depending on what you measure
same goes for kilo is it 1000 or 1024, again it depends on what you are measuring
and mega 1000 x 1000 or 1024 x1024
same goes for giga & terra
this link explains it a lot better than me http://www.lyberty.com/encyc/articles/kb_kilobytes.html
why is there no standard size format
18-07-2017 4:07 PM
there is.
end of thread
18-07-2017 4:15 PM
You missed out the MiB/GiB sequence notation which uses 2^10n
See wikipedia .
Though disk manufacturers use a hybrid 10^3n x 2^10 system
Phil
18-07-2017 5:21 PM
Remember 9/11. Is it the 9th of November, or 11th of September. In common sense land (Britain) it would be the 9th of November. Smallest division of date, by the second. In that order. Not second smallest division of date, by the first smallest division of date.
Then a great and brilliant individual went and created ISO 8601 standard. I love that person.
18-07-2017 6:12 PM
Ah! But why do we use decreasing unit sizes for times but increasing units for dates?
Hour>minute>second but day<month<year
18-07-2017 6:40 PM
18-07-2017 6:41 PM - edited 18-07-2017 6:44 PM
But not in the USA
Month>day<year
Or the ISO 8601 standard
Year>month>day>Hour>Minute>seconds
18-07-2017 6:45 PM
I use year>month>date eg 17-07-18 for documents, photos etc in PC folders - keeps everything in date order.
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
18-07-2017 6:56 PM
Me, too as well as documents like bank statements.
Forum Moderator and Customer
18-07-2017 7:11 PM
was just making a point. and inform peeps.
if you look you will see that 99% of bad reviews internet providers get are about low speeds. people think they are getting download speed in megabytes . if they knew it was megabit they would see that their speeds were ok.
its totally misleading to use bits. nothing except dowload speed is measured in bits. EVERYTHING else is measured in bytes.
problem is that if plusnet or any provider started to use bytes the speeds would look really slow compared to the other suppliers.
would you even consider 2MB/s max speed? even tho its about 2 x faster than 10 Mb/s.
most people just look at the number not the unit used
rocket science is prob less confusing lol
18-07-2017 7:45 PM
I'm sure we're all very grateful for the elucidation.
20-07-2017 11:07 AM
Shouldn't you have specified the Baud rate?
(Just to complicate the numbers a bit).
20-07-2017 2:27 PM
Go ahead and byte the bullet.
20-07-2017 2:47 PM
Are cyber wars fought with terrorbytes?
