non standardization of units in computing
mikcav
people think Mb means MB they are not the same
actually mb  mB Mb & MB are all different
even mb & mb can be different size depending on what is measured. { yea no typo both are lower case}
some measurements even use the WRONG symbols .  ie  using GB when it should be BB { think HDD or USB pen drive etc} is the reason your pc sees your HDD 7% smaller than you think you have
there are 8 bits to a byte or 10 depending on what you measure
same goes for kilo is it 1000 or 1024, again it depends on what you are measuring
and mega   1000 x 1000 or 1024 x1024
same goes for giga & terra
this link explains it a lot better than me    http://www.lyberty.com/encyc/articles/kb_kilobytes.html
why is there no standard size format
13 REPLIES 13
chenks76
All Star
Fixes: 12
Re: non standardization of units in computing
there is.
end of thread
PeeGee
You missed out the MiB/GiB sequence notation which uses 2^10n Huh
See wikipedia .
Though disk manufacturers use a hybrid 10^3n x 2^10 system Crazy2
Phil
Plusnet FTTC (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
People (and countries, namely the United States in the English speaking world) that use non-standard formats for time drive me up the wall. But they seemed to implement a lot of things just because they didn't want to do things like the country they'd just broken away from.
Remember 9/11. Is it the 9th of November, or 11th of September. In common sense land (Britain) it would be the 9th of November. Smallest division of date, by the second. In that order. Not second smallest division of date, by the first smallest division of date.
Then a great and brilliant individual went and created ISO 8601 standard. I love that person.
alanf
Ah! But why do we use decreasing unit sizes for times but increasing units for dates?
Hour>minute>second but day<month<year
Browni
Aspiring Hero
Fixes: 60
@mikcav what's your next lecture on?
Rocket science?
Image result for rocket emoticon
wisty
Fixes: 8
But not in the USA
Month>day<year
Or the ISO 8601 standard
Year>month>day>Hour>Minute>seconds
198kHz
Fixes: 41
I use year>month>date eg 17-07-18 for documents, photos etc in PC folders - keeps everything in date order.
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
Mav
Fixes: 515
Me, too as well as documents like bank statements.
Forum Moderator and Customer
mikcav
was just making a point. and inform peeps.
if you look you will see that 99% of bad reviews internet providers get are about low speeds. people think they are getting download speed in megabytes . if they knew it was megabit they would see that their speeds were ok.
its totally misleading to use bits. nothing except dowload speed is measured in bits. EVERYTHING else is measured in bytes.
problem is that if plusnet or any provider started to use bytes the speeds would look really slow compared to the other suppliers.
would you even consider 2MB/s max speed?   even tho its about 2 x faster than 10 Mb/s.
most people just look at the number not the unit used
rocket science is prob less confusing   lol
198kHz
Fixes: 41
I'm sure we're all very grateful for the elucidation.
VileReynard
Fixes: 20
Shouldn't you have specified the Baud rate?
(Just to complicate the numbers a bit).
Strat
Fixes: 565
Go ahead and byte the bullet.
198kHz
Fixes: 41
Are cyber wars fought with terrorbytes?
