nice metallic keyboard
techguy
Hi
I have a nice Logitech keyboard but it has all the plastic bits underneath the keys to damp the vibration of the switches.
I can get up a really good speed and rhythm on the metallic keybiards of old, does anybody know where I can buy a new keyboard with that type of feeling to it?
I ask as I'm doing a cisco course next year and of course router config requires the use of CLI.
Re: nice metallic keyboard
i presume you mean a buckling-spring keyboard like the IBM Model M ?
Keep your eye on eBay or google "clicky keyboard"
A Model M lasts "forever" and even a 25-year-old example would give you all the service you're likely to ever need.
Unused ones come up from time to time on eBay ... which is what I'm typing this with. Be prepared to fork out though.
techguy
Bang on Paul
My typing tends to be more accurate on those too, why the heck did they decide to make soft keyboards
Thanks for the reply, I'll have a look on ebay.
Thanks for the response.
Fixes: 348
Maybe i'll borrow one from work and put it on ebay just for you ;-)
I hate them myself and the noise when there are a few of your typing away on them is awful.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
techguy
Have a couple at work but they have seen better days and are probably a public health hazard if you know what I mean.
Good job you don't work with me then adiewoo as do hit the keys quite hard.
Njal
techguy
Cheers
scouring eBay for a good example as I speak
pierre_pierre
now you can say thank you properly
techguy
ROFLMAO
You ever thought about comedy? you really should.
