news.plus.net asking for authentication
HairyMcbiker
All Star
Fixes: 21
Looks like the old problem is back again:-
[11:00:35] Level: ERROR  SERVER=news.plus.net, MSG=Password: Server asked for Username and Password but, They aren't set
Going via gw4. (just reconnected as nntp was slow)
update:-
Just reconnected now via ag1 no problems, so looks like a problem with gw4 (vlan8.pih-gw4.plus.net)
10 REPLIES 10
Fixes: 1,483
Re: news.plus.net asking for authentication
seems to be OK here.
HairyMcbiker
All Star
Fixes: 21
What gw are you on?
Fixes: 1,483
ag1 like you are now Smiley
HairyMcbiker
All Star
Fixes: 21
Getting the same today on gw4 again.
switched to ag-1 and fine, so def. a problem on gw4
same problem on ag-3 and ag-4 (switched because ag-1 was slow <1.5Mb when it should be >4Mb)
bobpullen
Fixes: 316
Odd that this should be happening as we've not made any recent changes. I've just got this though.
C:\Users\bpullen>tracert mail.plus.net
Tracing route to mail.plus.net [212.159.8.81]
over a maximum of 30 hops:
  1    78 ms    99 ms    99 ms  home.gateway [192.168.1.254]
  2    20 ms    19 ms    19 ms  lo0.plusnet.thn-ag1.plus.net [195.166.128.101]
  3    20 ms    21 ms    26 ms  vl703.thn-gw1.plus.net [84.92.4.241]
  4    20 ms    25 ms    35 ms  ae0-102.ptn-gw01.plus.net [212.159.1.53]
  5    32 ms    31 ms    20 ms  gi0-1-31.ptc-gw1.plus.net [195.166.129.3]
  6    44 ms    37 ms    28 ms  pos1-0.pih-cr1.plus.net [195.166.129.250]
  7    28 ms    35 ms    29 ms  vlan7.pih-gw3.plus.net [212.159.0.26]
  8  112 ms    62 ms    32 ms  if25.pih-lb04.plus.net [212.159.0.18]
  9    37 ms    26 ms    27 ms  mail.plus.net [212.159.8.81]
Trace complete.
C:\Users\bpullen>telnet news.plus.net 119
200 News.GigaNews.Com
group plusnet.service.customer-feedback
480 authentication required
Having said that I've just tried again without disconnecting/reconnecting and all seems OK now.
211 20405 14 20418 plusnet.service.customer-feedback
It's worth bearing in mind that you'll get an authentication prompt if you exceed the maximum number of allowed threads from the same IP (which I think is set to 4).
HairyMcbiker
All Star
Fixes: 21
I haven't changed any settings and it is VERY intermittent, changing gw's usually cures it but today it seems to be following it.
It was ok but now back to asking for a u/p.
Connections set to 4 and hasn't changed.
from newsbin
[13:49:36] Level: ERROR  SERVER=news.plus.net, MSG=Password: Server asked for Username and Password but, They aren't set
repeated ...
bobpullen
Fixes: 316
Would be interesting to see if the problem persists if you lower the number of threads you're using to 2?
HairyMcbiker
All Star
Fixes: 21
I dropped them to 3 and it seems to be holding at the moment. Will monitor it to see if it continues.
Why had the number of threads dropped? Giganews usually offer 10 threads.
bobpullen
Fixes: 316
Quote from: biker955
AFAIK it hasn't. Here's an excerpt from my Newsbin logs (with the server configured to use 4 threads):
[13:17:42] Level: HIGH   SERVER=news.plus.net, MSG=220 0 <AnThCOoh8rrfdJPgEms@JBinUp.local>
[13:17:41] Level: HIGH  SERVER=news.plus.net, MSG=220 0 <OC6fDJ3CotFPjN4U6cIA@JBinUp.local>
[13:17:41] Level: HIGH  SERVER=news.plus.net, MSG=ARTICLE <OC6fDJ3CotFPjN4U6cIA@JBinUp.local>
[13:17:40] Level: HIGH  SERVER=news.plus.net, MSG=220 0 <C87BKkvCcJLkSXHTmLKA@JBinUp.local>
[13:17:40] Level: HIGH  SERVER=news.plus.net, MSG=ARTICLE <AnThCOoh8rrfdJPgEms@JBinUp.local>
[13:17:40] Level: HIGH  SERVER=news.plus.net, MSG=ARTICLE <C87BKkvCcJLkSXHTmLKA@JBinUp.local>
[13:17:35] Level: HIGH  SERVER=news.plus.net, MSG=220 0 <LDcgsnbWXswRWiqlEudD@JBinUp.local>
[13:17:34] Level: HIGH  SERVER=news.plus.net, MSG=ARTICLE <LDcgsnbWXswRWiqlEudD@JBinUp.local>
[13:17:22] Level: HIGH  SERVER=news.plus.net, MSG=220 0 <SgRNeriwVdsuztFosrm9@JBinUp.local>
[13:17:21] Level: HIGH  SERVER=news.plus.net, MSG=220 0 <Ot0pc6dbKqpO09RLIgo7@JBinUp.local>
[13:17:21] Level: HIGH  SERVER=news.plus.net, MSG=ARTICLE <SgRNeriwVdsuztFosrm9@JBinUp.local>
[13:17:21] Level: HIGH  SERVER=news.plus.net, MSG=220 0 <rSn7ZdKcJOfAhHtJ7kn1@JBinUp.local>
[13:17:21] Level: HIGH  SERVER=news.plus.net, MSG=ARTICLE <Ot0pc6dbKqpO09RLIgo7@JBinUp.local>
[13:17:21] Level: HIGH  SERVER=news.plus.net, MSG=ARTICLE <rSn7ZdKcJOfAhHtJ7kn1@JBinUp.local>
[13:17:13] Level: HIGH  SERVER=news.plus.net, MSG=220 0 <acGqLSOdTIoM8SlNqcb5@JBinUp.local>
[13:17:12] Level: HIGH  SERVER=news.plus.net, MSG=ARTICLE <acGqLSOdTIoM8SlNqcb5@JBinUp.local>
[13:17:02] Level: HIGH  SERVER=news.plus.net, MSG=220 0 <SHi1UQZOYFciUpfqYIC2@JBinUp.local>
[13:17:02] Level: HIGH  SERVER=news.plus.net, MSG=220 0 <EGrZltlMh59KbM7oIjTB@JBinUp.local>
[13:17:02] Level: HIGH  SERVER=news.plus.net, MSG=ARTICLE <EGrZltlMh59KbM7oIjTB@JBinUp.local>
[13:17:02] Level: HIGH  SERVER=news.plus.net, MSG=ARTICLE <SHi1UQZOYFciUpfqYIC2@JBinUp.local>
[13:16:59] Level: HIGH  SERVER=news.plus.net, MSG=220 0 <ccdvZjC6UiPnEXe0Sb44@JBinUp.local>
[13:16:59] Level: HIGH  SERVER=news.plus.net, MSG=ARTICLE <ccdvZjC6UiPnEXe0Sb44@JBinUp.local>
[13:16:53] Level: HIGH  SERVER=news.plus.net, MSG=220 0 <O5UEcUzBrEmBSo1fwhZE@JBinUp.local>
[13:16:53] Level: HIGH  SERVER=news.plus.net, MSG=ARTICLE <O5UEcUzBrEmBSo1fwhZE@JBinUp.local>
[13:16:42] Level: HIGH  SERVER=news.plus.net, MSG=220 0 <P2QGSE5RamruWKB09zH2@JBinUp.local>
[13:16:42] Level: HIGH  SERVER=news.plus.net, MSG=220 0 <D3yRj9bJYEsINl8qP9cA@JBinUp.local>
[13:16:40] Level: HIGH  SERVER=news.plus.net, MSG=220 0 <wDKik4Ww55lbVYPV2WVE@JBinUp.local>
[13:16:40] Level: HIGH  SERVER=news.plus.net, MSG=ARTICLE <wDKik4Ww55lbVYPV2WVE@JBinUp.local>
[13:16:40] Level: HIGH  SERVER=news.plus.net, MSG=ARTICLE <P2QGSE5RamruWKB09zH2@JBinUp.local>
[13:16:38] Level: HIGH  SERVER=news.plus.net, MSG=ARTICLE <D3yRj9bJYEsINl8qP9cA@JBinUp.local>
[13:16:35] Level: HIGH  SERVER=news.plus.net, MSG=220 0 <pblnUCK1oWOwxO9wtfq1@JBinUp.local>
[13:16:32] Level: HIGH  SERVER=news.plus.net, MSG=ARTICLE <pblnUCK1oWOwxO9wtfq1@JBinUp.local>
[13:16:22] Level: HIGH  SERVER=news.plus.net, MSG=220 0 <togen76QVLO4At9kt1WB@JBinUp.local>
[13:16:21] Level: HIGH  SERVER=news.plus.net, MSG=220 0 <DU0FBToLkYg5IPSZSQ93@JBinUp.local>
[13:16:20] Level: HIGH  SERVER=news.plus.net, MSG=220 0 <Sz6pTADSUQPrpg8XqEJ@JBinUp.local>
[13:16:20] Level: HIGH  SERVER=news.plus.net, MSG=ARTICLE <Sz6pTADSUQPrpg8XqEJ@JBinUp.local>
[13:16:18] Level: HIGH  SERVER=news.plus.net, MSG=ARTICLE <togen76QVLO4At9kt1WB@JBinUp.local>
[13:16:17] Level: HIGH  SERVER=news.plus.net, MSG=ARTICLE <DU0FBToLkYg5IPSZSQ93@JBinUp.local>
[13:16:15] Level: HIGH  SERVER=news.plus.net, MSG=220 0 <U0oprI30E2pZSezUUYr8@JBinUp.local>
[13:16:11] Level: HIGH  SERVER=news.plus.net, MSG=ARTICLE <U0oprI30E2pZSezUUYr8@JBinUp.local>
[13:16:02] Level: HIGH  SERVER=news.plus.net, MSG=220 0 <X9ljTBFOXyJUQRQSkb98@JBinUp.local>
[13:16:02] Level: HIGH  SERVER=news.plus.net, MSG=220 0 <XBUFCXEiIu0D0rujS5I9@JBinUp.local>
[13:16:02] Level: HIGH  SERVER=news.plus.net, MSG=220 0 <HzZq26WJW548sk1XdWL6@JBinUp.local>
[13:16:02] Level: HIGH  SERVER=news.plus.net, MSG=ARTICLE <XBUFCXEiIu0D0rujS5I9@JBinUp.local>
[13:16:00] Level: HIGH  SERVER=news.plus.net, MSG=ARTICLE <X9ljTBFOXyJUQRQSkb98@JBinUp.local>
[13:15:59] Level: HIGH  SERVER=news.plus.net, MSG=ARTICLE <HzZq26WJW548sk1XdWL6@JBinUp.local>
[13:15:55] Level: HIGH  SERVER=news.plus.net, MSG=220 0 <hqvVguYUDORk0Ft68mP1@JBinUp.local>
[13:15:55] Level: HIGH  SERVER=news.plus.net, MSG=ARTICLE <hqvVguYUDORk0Ft68mP1@JBinUp.local>
[13:15:42] Level: HIGH  SERVER=news.plus.net, MSG=220 0 <J5YZVweWDmPTbJokgxa8@JBinUp.local>
[13:15:42] Level: HIGH  SERVER=news.plus.net, MSG=220 0 <2Mkr04XWOBjUCWlsgdoC@JBinUp.local>
[13:15:42] Level: HIGH  SERVER=news.plus.net, MSG=220 0 <dOV8chV2vju01FFFi195@JBinUp.local>
[13:15:42] Level: HIGH  SERVER=news.plus.net, MSG=ARTICLE <2Mkr04XWOBjUCWlsgdoC@JBinUp.local>
[13:15:42] Level: HIGH  SERVER=news.plus.net, MSG=ARTICLE <dOV8chV2vju01FFFi195@JBinUp.local>
[13:15:42] Level: HIGH  SERVER=news.plus.net, MSG=ARTICLE <J5YZVweWDmPTbJokgxa8@JBinUp.local>
[13:15:41] Level: HIGH  SERVER=news.plus.net, MSG=220 0 <N9qg0N1kcdABxa9rnwEt@JBinUp.local>
[13:15:41] Level: HIGH  SERVER=news.plus.net, MSG=ARTICLE <N9qg0N1kcdABxa9rnwEt@JBinUp.local>
Could it be that you have a Plusnet news account configured in another client that's open at the same time? (something like Thunderbird for example)
HairyMcbiker
All Star
Fixes: 21
Nope the only news client I have is newsbin. Very strange, well it is working with 3 I will leave it.
